Danger Den Hold down Bracket /Slit-Edge
Steel_Dreams
Florida
Hi all just thought you should know that the Danger Den Maze 3 Bracket will work with the Slit Edge water block .i just installed it on my MSI K7N2 Delta-ILSR i did install alittle longer springs on the bracket and because of a capacitor next to the cpu i had to cut off one of the P4 Holes on the slit Edge ,ie it comes with both Intel P4 and AMD hole`s on the socket ,but it was no biggy . Temps are looking good 1700+ T-bred @ 1833 Mhz at idle 32C to 33C . i cant do a Full load till i reformat my Drive and reinstall win xp .i also tryed my DTek TC4 r 2 Block it was a no go the bracket wont work with the offset inlet and outlet ... ok later
