Sounds like that psu will work good for ya. I got a smaller psu that is suposedly rated at 32amps cont. but my 220watt pelt can cause my psu to overheat which shuts down. Not really a problem I just added another fan just above heatsink for the transformer.Bender said:Hey Colin just to let you know I finally found a good psu and a 220 watt peltier. I'm getting an astron 50 amp (36 const) so I don't think I'll have any problems. The only thing I don't like is the weight of the astron. Its a 45 pund chunk of metal. I cant wait to give this setup a try.
Before accident, my test system was a 600duron@1000Mhz with 1.85vcore and full load temps were between 7-9c. What are you planing on cooling with your pelt?Bender said:Hey racecar12 I was also thinking of adding a fan but I don't think it will need it. What are your system specs and what are your temps like with the 220?
racecar12 said:Sounds like that psu will work good for ya. I got a smaller psu that is suposedly rated at 32amps cont. but my 220watt pelt can cause my psu to overheat which shuts down. Not really a problem I just added another fan just above heatsink for the transformer.
