Senater_Cache said:RedVGiper is right according to that graph, the D4 is clerly the better pump (equal head more GPH)
Section8 said:The swiftech has a much better curce in that graph. Why does he say the DD pump was the best? The swiftech clearly was better? Good review though other than that.
Section8 said:Yes it does but at 7 feet it hits 0. Don't high performance Water Cooling Systems use restrictive blocks that increase pressure? If so than wouldn't you want a pump that could perform better at a higher pressure? If you look at the overall curve I would rather get the Swiftech. The DD also runs at 24 watts but says it only requires 18 watts where the Swiftech only requires 9. Other than that it does look good.
Section8 said:My bad I am color blind I guess? I was looking at the wrong color...
But yes 1 degree would impact my buying decission. 1 degree here 1 degree there adds up you know.
lucas81 said:http://forums.overclockers.com.au/s...=1706046&sortby=lastpost&sortorder=descending
check there, there are quite a few people with experience with them. You could also do a search on the name Cathar, he knows a lot of the pumps.
Ancient_1 said:Actually Cather stated it was about the same as a med speed 60mm fan @ 12v and a delta screamer at 16v.
RedViper said:One thing I've noticed about the water-cooling scene: Long-timers and people in the know tend to be hostile towards the idea of anything new. It's like they tie their egos to the component choices they've made. The only real innovation that seems to creep into the discipline appears to come from the bottom up, as new people buy in.
