- Apr 25, 2001
- Philthadelphia
I had posted earlier about my watercoling system losing water, well, I found the problem. I checked again in the morning and found some really soggy foam under my Danner pump and a small puddle at the bottom of the case. Luckily there were no electronics under it. Apparently I'm not the first person to have this problem either. I do want to warn anyone using this pump or who will be using it of this problem. The leaks occur around the front cover (with the in and out pipes). Tightening the screws made it worse. The molding seam on ours also turned into a crack and leaked. We took it apart and are going to seal it up with some good sealant. I'll post an update of how it worked. We are doing it similar to an article on Procooling.com.
-Rav
-Rav
