- Feb 15, 2003
OK so I've been doing a ton of reading lately on what pump to get. I narrowed it down to 2 contenders: Danner Mag 3 and Eheim 1250. The basically have the same gph, but the danner has bigger head (11' I think). In any case the put around the same amount of head into the water, so that's no trouble.
Since this will be my first WC system, I need top-notch reliability in the pump (can't afford *any* leaks at all
). I'm a little short on space, so my PC will be placed next to my CRT monitor. Hence my questions:
1) Which pump is more reliable?
2) Which pump is quieter?
3) Which pump gives off less EM radiation?
Thanks for your help
btw, can someone please point me to a thread which discusses how to fix that O-ring problem for the danner (I couldn't find it from search).
