bkoehn
- May 8, 2017
- Minneapolis, MN
I'm sure this has been discussed before, but I'm looking for some input on my custom loop configuration.
I already have most of the components, so will be putting together soon.
Briefly > NZXT h440 case, i7 6700K, GTX 1080 FE.
I'm not looking to mod the case (yet), and will be bottom mounting my 'games' HDD.
This means a 360 rad on top with a 280 at the front.
Does it matter how it is piped? i.e. should the liquid hit one radiator, then CPU block; then another radiator followed by the GPU block?
Or should I simply run Rad > CPU > GPU > Rad > pump for a cleaner/easier loop.
I don't like the idea of CPU warmed coolant hitting my GPU, but is the flow rate fast enough to make this a non-issue?
