David's Learning and Rambling Thread
Must ... make ... PiFast ... run ... before .... Windows .... cr .. BAH!
EDIT: Woot!
MOAR VOLTS!
I'm going to get through all the tests I can without increasing volts.
Then I'm going to set it for 1.7 V and pray to <insert deity of choice> that I don't get left with a gaping charred hole in my desk.
1.7 on air? Been there done that. ;)
Sod it... here we go then...
EDIT: Balls. Boots, complains of over-voltage, says press F1 to continue, shuts off. :(
What board are you using? You should be able to turn off Voltage Monitoring in BIOS to prevent that error from popping up. I know I had to do it on my Asus P5Q-E to get past 1.6V
:D
Asus Rampage Formula, with the latest BIOS.
1.65 V behaves itself, got UCBench to run at 4240 :)
EDIT: Got PiFast and wPrime32M to run at 4240 as well. Score.
In BIOS:
- Go to POWER Section
- Go to HW Monitor
- Go to CPU Voltage: You should be able to set it to IGNORE in there.
:D
Can always just push F1 as well. My P5Q Pro left the voltage applied even if it complained.
As a note, throttling on P4s starts around 70c if I recall correctly, so you may need some more cooling.
Cheers!
Looks like HWBot is buggy again, it's not putting my results into the right rankings... ugh.
Anyway, should manage a few boints out of this lot. Now I know how to ramp up the vcore ...
Editing gubbed submissions to 2x CPU then back to 1x fixes the rankings issue. :)
Actually picked up some HW points so I'm very happy.
Cheers! I'm getting some better scores than I expected (perhaps its the RAM).
The P4 530 is being a pain. I can adjust FSB up to ~ 285 (with various FSB straps) but after that it misbehaves - the CPU speed goes down not up ... I don't think SetFSB goes past 250 MHz so I don't think it'll help.
EDIT: 1.65 V on vcore, HW monitor says 40C idle in BIOS.
SetFSB might need the "advanced mode" options changed. Alternatively you can hit the "turbo" checkbox. Either way will let you extend the slider bar dramatically.
Cheers :) I'll give it a shot tonight.
I also need to disable my own 'Newb Mode' ...
4277.56 out of the P4-530, but that needed 1.7 V. Anything higher and SetFSB ****s itself 10 seconds before the machine crashes.
Going to see how high I can get some of these benches to run at: I'll not come first in all of them, but I can hopefully fill in the gaps.
530 done with. Back to the C2D to see what I can get for the NVS285 on some 3D.
EDIT: Even with 1.75 V (low temps - 40s under moderate load) it wont go past 470 MHz FSB. 475 causes the whole thing to freeze up. Going to see if I can complete the benches at 3290 MHz :cool:
I was at 1.49 V (on air, fan aimed at NB). I'll try bumping it up a little tonight.
