DD vid TEC
water_cooler 20
FL, USA
I ordered a R9800 w/256 Vram :D :D
But lets get to the point i want to get a big oc out of it.I have a DD vid WB hanging around(was going to put on my R9000 but i don't)I wanted to know if its possible to put a tec on the WB.I will also be using chilled water.
Bender
Mysteriously Changing Senior
In Thelemac's Basement Eating the Chickens
The dangerden block is a fine cooler but it’s not really made for a TEC. TECs need lots of pressure to work efficiently so a bolt on coldplate is a must. If you can rig up a bolt on coldplate for your DD block then give TEC cooling a try. If you don’t want all the fuss try a Swiftech MCW50-T. It’s a VGA waterblock with an 80 watt TEC. Don’t forget neoprene insulation :eek:
www.swiftech.com
