im trying to find out what my best OC results would be with a 1.8A or 2.0A on a ASUS P4B533-E or the P4T533. Im not sure which would OC better... DDR400 or RDRAM. Im confused because i thought that a DDR400 solution is better for OC. Anyway, when it comes to ram money is no object. If RD is the way to go then thats wut i get. Please help me understand wjat a better solution is for the best OC.
I've removed this from your sig.......please shorten it a bit or just reformat it. We also don't allow bypassing the profanity filters....take that in to consideration when you DO change your sig.
AMD Athlon XP-1800+ @ 1650MHz (11x150) 1.80v
SK-6 Copper HS w/60mm Delta
Arctic Silver II
Abit KG7-Raid
"MrIcee's MB Optimization"
2x 256 Micron PC-2100 DDR
1x IBM 40GB GXP-60 ATA-100 7200RPM
1x Quantum 20GB ATA-100 7200RPM
Abit Siluro Ti-4200 128MB DDR 315/585
Creative SB-Live! Value 5.1
Intel NIC
RealTek NIC
Sony 8X8X32
Creative 6X DVD
Creative 52X CD-Rom
Digital Doc 5 Fan Controller
2x Antec Case Fans
2x ThermalTake Case Fans
Antec 400w PSU
Antec 1040B Case
(Mem @ Cas 2 w/Custom Settings)
3D Mark 2001 SE (Win-XP):
11241 Det 40.41
3D Mark 2001 SE (Win-2K):
11413 Det 40.41 @ 315/575
" I prolly spend about a half hour on my pc a day, I kid you not ppl.
Shadow ÒÓ
Arctic Silver II
Abit KG7-Raid
Intel NIC
RealTek NIC
Sony 8X8X32
Creative 6X DVD
Creative 52X CD-Rom
2x Antec Case Fans
Antec 400w PSU
Antec 1040B Case
11241 Det 40.41
Shadow ÒÓ
