Hi guys,
I am not very experienced in this. Basicly I hav two kits of rams
1. 2x2 Corsair CM2X2048-6400C 4DHX
2. 2x1 A-Data Extreme DDR2 800+
both are supposed to run on 800Mhz 4-4-4-12
but when I run CPU-Z I get this:
I tryed to change it in Bios, but it did not work.
I know how to change timing to 4-4-4-12 I also know how to change DRAM voltage to 2.0 or 2.1V
but I struggle with the frequences, there is FSB frequency and DRAM frequency. If its set as on the printscreen from Bios, It does not work. Also do I need to change anything else in Bios?
This is from the manual:
Can you help me to solve this?
