ddr3 corsair 1.8v with X58 ?
Stvwndr219e
1.8 is very high for a x58 board. Remember that the VTT has to stay within .5 of the Dimm voltage. I'm not comfortable with it being that high and intel specs are 1.65v for the RAM I believe. Mem controller on 920 may not be strong enough for 1.8v either.
KGH
KGH
San Jose, CA
I thought so too. However, i have seen others running those sticks on x58 boards.
Just need to hear from them as giving me a green light.
Stvwndr219e
hehe, well you could always try and see if they'll run at 1.65v at those timings. Wouldn't hurt if it doesn't work.
Neuromancer
Tau'ri
Yup as long as you keep it within .5 VTT you are fine.
Intel specs are for 1.35 or 1.38 max VTT IIRC.
So to me that was a starting point :) And as long as everything is balanced and you keep stuff cool you will be okay.
As far as ram goes... that kinda high voltage for DDR3 is not common.. must be some especially bad ICs.. dont know of the top of my head. Rip off the heatspreader if you cant google the info and find out what ICs are on there.
If still not good. (OCZ rebranded) OC them see what needs what and google some more,... figure out what ICs they are based on performance clocks at volts... and get a good idea of what they CAN do.
I pushed my cheap *** sticks above 2.1 Gigs at 1.9 volts. 9-9-9 2Gig at 1.875 8-8-8 and ran them routinely at 1.8-1.85 7-7-7 from 1700 -1800 :)
KGH
KGH
San Jose, CA
sounds like a good plan...I will give it a try.
I believe this RAM came out for those X48 w/ DDR3 so the V lil high.
