DDr3 Memory with an Athlon II x2 250
carlp
Hi everybody!
I've finally enter the 21th century and buyed a new computer. There's a AthlonII x2 250 based model on a m4a785td-v evo MB. And i'm also a proud owner of a ati radeon hd 5850 :cool:
My problems comes with the Memory module...
I need some DDR3 first of all! Considering my CPU, how many hertz should I get? 1333 or 1600? I'll overclock for sure! 1600 sound cool but in fact, will it be noticable or even useful (is it for intel i5 and i7 computer anyway?)
Secondo: How many Ram I really need? I game, usually. I'm not a big player but I love to play in hi def.
Do 4Gb of Ram will be enough? or I need more? I got to stick with the dual channel too, cause my board is made for this
Thanks for your reply!:thup:
thanks for the fast reply!
Just to be sure, I will play game like COD modern Warfare 2 and other recent game like that. 4 GB is enough?
And it seem that the only 7-7-7-20's timed memory out there are the OCZ gold, witch I dont trust at all, and the corsair Dominator wich at 178.99 is fairly overprice for me.
I'm in a shoestring budget but let's say a silvershoestring! :p
OCZ is fine, but any 7-7-7 should do. Those Corsair Dom GT sticks are way overkill for your purposes.
Where are you shopping for RAM? Are you in the US? G.Skill Ripjaws are always a good choice, I couldn't be happier with mine. Mushkin is also a good choice.
You can get some 8-8-8 stuff, but the price isn't much better ($10 or so) so I don't see a reason to. Same with the 1333 kits, I don't see the small price break outweighing lower (guaranteed) performance.
