- Oct 13, 2011
The wife and I wanted another computer for gaming/general purpose. We want to try to go for a good price for the power build. I looked around at a few things and these items seemed good for the price and our needs. Looking for any input on things that might be a better option. This should be around $700-800. We would like to keep the build around that or cheaper.
GPU: $170
EVGA 02G-P4-3757-KR GeForce GTX 750 Ti 2GB 128-Bit GDDR5 PCI Express 3.0 FTW w/ ACX Cooling Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487028
Updated GPU: $199
XFX Double D R9-270X-CDFC Radeon R9 270X 2GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150686&cm_re=270x-_-14-150-686-_-Product
CPU: $199
Intel Core i5-4570 Haswell 3.2GHz LGA 1150 84W Desktop Processor Intel HD Graphics BX80646I54570
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116896
Mobo: $99
ASUS VANGUARD B85 LGA 1150 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132099
SSD: $110
Crucial M500 240GB SATA 2.5" 7mm (with 9.5mm adapter) Internal Solid State Drive CT240M500SSD1
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148694
RAM: $78
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
Power Supply: $79
CORSAIR CXM series CX600M 600W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139048
Updated Power Supply: $50
CORSAIR CX series CX500 500W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
Case: $59
Cooler Master HAF 912 - High Air Flow Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
GPU: $170
Updated GPU: $199
CPU: $199
Mobo: $99
SSD: $110
RAM: $78
Power Supply: $79
Case: $59
