Hello,
It's been over 15yrs since I last built a PC and I know things have changed that I feel like a noob. Please Help. So here's the issue...
After getting everything hooked up I inserted the USB flash drive to boot up windows install. After it went thru the windows check list, I was taken to the serial prompt. After entering my serial and pressing Enter the machine would continue Windows and then reboot.. As if the power cut out and restarted again. This would continuously happen and be stuck in a loop. After restarting I would sometimes get to a windows dialogue that says windows wasn't properly installed. I would try to get into the Bios to boot into the USB again to reinstall, and I would see several partitions probably created by the reboot loop of trying to install windows. Also sometimes, while in BIOS the machine would reboot, again as if someone cut the power and started it up again.
Here's my rig... It's going to be used for Video/3D Rendering/Graphics
CPU : Intel Xeon E5-2697V4 2.3 GHz 45 MB L3 Cache LGA 2011-3 145W
MOTHERBOARD: Asus X99-E-10G WS OR ASUS X99-E- WS
COOLER: Noctua NH-D15 82.5 CFM CPU Cooler
RAM : Crucial 64GB (4 x 16GB) 288-Pin DDR4 SDRAM ECC DDR4 2133 (PC4 17000) Server Memory Model CT4K16G4RFD4213
GRAPHICS CARD : Quadro M5000
POWER SUPPLY: EVGA SuperNOVA 1200W or Corsair 1200i
M.2 : SAMSUNG 960 EVO M.2 1TB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E1T0BW
DRIVE : SAMSUNG 850 EVO 2.5" 1TB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E1T0B/AM
OS: Win10Pro
in my first attempt, I had Asus x99-e-10G WS and the EVGA 1200W PSU. Temperatures average about 30 degrees.
- I updated the BIOS of the board, flash the CMOS, switched out the RAM, to a single different stick, switched out the PSU, checked the connections. And still got similar results.
- Could it be the motherboard or the CPU or even the graphics card?
- Someone told me I should install with a basic graphics card before I upgrade to my Quadro M5000 professional card
- Do I need another motherboard that's not x99?
- Ive seen X99 mobos are supported with XEON and I've read they are not. But the mobos I'm listing say it is supported or am I wrong.
I'm currently getting my CPU replaced just in case and switching out my motherboard to the ASUS X99-E- WS 3.1. I'm hoping one of these components was defective and solve my issues when I get the new parts.
Has anyone encountered these issues?
OS: Win10Pro
