Shaitan said:
You still haven't told us just how much temps dropped after the full mod. I wanna know
I wasn't satisfied with the triple setup, and started playing with the idea of just two of the fans, but not mounted coaxially. This should give less pressure, but more overall volume (CFM). I designed a prototype fan shroud of plastic and electrical tape, with the two fans side by side, each angled about 45 degrees from the heatsink (think of the fans as two sides of a triangle). The final device will be made of aluminimum or steel. This prototype has given me the best cooling yet with a load temp of 42C degrees.
I'm posting now, as I have disassembled the prototype, and have tested with just one fan, with two fans coaxially, and all three fans coaxially (DeepThroat). The resulsts:
Single Fan (SuperRed): 47.5C degrees under load
Plus 1 NMB coax: 45.0C degrees under load
Plus 2 NMB coax: 44.5C degrees under load
*Prototype dual: 42C degrees under load
Although the pressure is impressive, it appears at this point that the 3rd coaxial fan isn't worth the effort, as the measured drop is within margin of error--meaning almost no distinguishable drop, here 0.5C degrees observed. Two fans coaxially, however, gave a consistent measurable drop of 2.5C degrees over the single fan device.
I'm encouraged by the initial dual side-by-side prototype, and am anxious to get the final device finished. The prototype showed a decrease of 5.5C degress over the single fan (the 2 NMBs in this case, with the SuperRed retired). I expect even better performance from the final device, as I plan to install a vertical deflector panel in between the two fans, which was not implemented in the prototype. This divider will accomplish two things:
1. Eliminate any turbulent interference between the outputs of the two fans
2. Produce full flow coverage of all the surface area of all sink fins
I'll post pictures and temp results when I have this next design finished and installed.
