martinlest
- Nov 25, 2015
Hi. I have a PC (5 years old now, I use it as a second machine) which has been working just fine until this week, but when I boot (into Windows 7 (x64) ) the PC soon freezes up completely, or I get a BSOD (the PC rebooted - I have changed the settings so it won't in future and will note down details). I do have one crashdump file (ntoskrnl.exe problem), but what I want to try at the moment is to return the clock settings to default. The M/B is a p6x58d-e. Googling has found lots (of course) on overclocking but all I can find is the default CPU Voltage (1.18).
The P/C has always been overclocked with no problem, giving a stable 3.8GHz. The settings I was using are below. Last week the O/C failed and in the BIOS the CPU Voltage of 1.30000V, which had been OK for years, was in purple, indicating a problem. The highest I could get the BIOS to accept was 1.20000. But I made no other changes to settings in the BIOS - maybe this is where the problem lies, changing the CPU Voltage alone?? I can enter the stock value of 1.18000V for CPU Voltage, but what else to I have to change in the following settings to return the PC to its default clock settings (DRAM Bus Voltage???). As this is not my principal PC any longer, I have no reason to overclock, if that is what is causing the problems now. (Any other suggestions as to the cause, otherwise?).
I checked Core temps BTW - all are fine under load. Running an AVG anti-virus scan has all cores running near max though, is that normal?? The PC freezes up after a while...
I am also running Memtest84 - no problems shown so far.
Thanks!
Martin
Ai Overclock Tuner Manual
CPU Ratio Setting 19.00
Intel (R) SpeedStep(TM) Tech Disabled
Xtreme Phase Full Power Mode Auto
BCLK Frequency 200
PCIE Frequency 100
DRAM FREQ 1603MHz
UCLK Frequency Auto
QPI Link Data Rate Auto
ASUS/3rd Party UI Priority ASUS Utility
- DRAM Timing Control (All Auto)
CPU Voltage Control Manual
CPU Voltage 1.30
DRAM Bus Voltage 1.64
CPU Spread Spectrum Disabled
Intel HT Technology ENABLED
Thanks!
Martin
BCLK Frequency 200
PCIE Frequency 100
DRAM FREQ 1603MHz
UCLK Frequency Auto
CPU Voltage 1.30
