- Jan 15, 2001
- Denver, CO
- Thread Starter
- #21
No I didn't take any pics because I figured there were already enough on the net. Basically all I did was orient myself so I knew which four holes on the socket I needed to connect, and then I slowly painted between them using a sewing needle. Just go slow and use some glasses to make sure you aren't getting too close to the neighboring holes. Oh and if you do screw up you can simply wipe it off with acetone and start over.
