- Mar 27, 2004
- Pittsburgh Pennsylvania
As some of you might know, Pwnt by Pat has been working on a dehumidifier chiller project, this is that project.
http://img78.photobucket.com/albums/v314/Pro*Banshee/Chillerbox.jpg
Here's the nice wooden 'shipping crate' I built for it, it stands up nicely to the 210-pound-kid-sitting-on-it test, so I guess it'll hold the chiller just fine.
http://img78.photobucket.com/albums/v314/Pro*Banshee/Caster.jpg
one of the four casters used to help this beast move around, fully loaded or not.
http://img78.photobucket.com/albums/v314/Pro*Banshee/DehumidifierFR.jpg
http://img78.photobucket.com/albums/v314/Pro*Banshee/DehumidifierBK.jpg
The dehumidifer, a 40 pint unit. I expect at least -20c coolant temp from this unit
http://img78.photobucket.com/albums/v314/Pro*Banshee/Foambox.jpg
Here are the 4" brass threaded tubes and their prequisite fittings, which are going to penetrate the foam box, the outside wall, and the interior space. They are going to be insulated with plenty of spray on foam, since that's what cool kids use.
http://img78.photobucket.com/albums/v314/Pro*Banshee/WholeFR.jpg
Here is the unit as a whole from the front 3/4 view. As you can see, the foam box is big enough for the entire computer to fit inside the unit, which I think I might do, I'm not sure yet.
http://img78.photobucket.com/albums/v314/Pro*Banshee/WholeBK.jpg
And the rear, nothing much to see here
Some cool things about it:
well, just one. So far, when the pink box is filled to the brim with water, it freezes solid in under three hours.
This is an ongoing project, Keep watching, I promise temps when I'm finished!
