delete files in C++
Bmxpunk86pl
CT/Poland
how do i delete files in C++?
do i do this:
remove ("C:\\test.txt");
but when i do that, it will not delete the file. I dont get any errors but it just doesnt delete the file.
p.s. there is more to the program, this is just a snippet.
thanks,
Adam
Krieger
North of Boston, MA
there is a better way that I can't think of but you can execute a system command "Del xxx.tmp". You'll ahve to look up the acutal function, I can't think of it off the top of my head. It's something like "syscom('Del xxxx.tmp')". But Like I said it's been a while.
Bmxpunk86pl
Bmxpunk86pl
CT/Poland
i get an error saying that:
7 untitled1.cpp implicit declaration of function `int system(...)'
i wrote this:
#include <stdio.h>
#include <fstream.h>
#include <iostream.h>
int main(int argc, char *argv[])
system ("del C:\\test.txt");
return 0;
anyideas?
Thanks,
Adam
engjohn
Senior Member
SoCal
you are not including the header file that contains the definition for the function system()...
I cannot remember what it is right now.... But, that is your problem.
*edit*
Ahhh, I remeber now, it is the "process.h"
Bmxpunk86pl
Bmxpunk86pl
CT/Poland
alright i did it but it doesnt delete the file for some reason. Here is my program:
#include <stdio.h>
#include <process.h>
#include <stdlib.h>
return 0;
jokrswild
Ohio
maybe i'm just nuts, but
do you really need both slashes "c:\\test.txt"???
try cutting it down to one: "c:\test.txt"...
Only thing i could think of.
Bmxpunk86pl
Bmxpunk86pl
CT/Poland
no because of what C++ uses the '\' for, it will not work. Because C++ was made under Unix and unix does not use "\". C++ uses \n, \t, so it though that i was using that. So u gotta use the double back slashed. Also i got it to work, so now i can delete files.
Cowboy Shane
Augusta, GA
You have to use the double back slashes so the compiler knows you're not trying to use an escape character, ie \n \t . I don't think it has anything to do with being designed for Unix.
Cowboy Shane
Augusta, GA
Not exactly what you said before. I guess I should have been clearer. Since C++ defines the backslash as an escape character, there needed to be a way to instruct the languages you really just want a backslash. The obvious solution is to leave the backslash as an escape character and follow it by the symbol \ which is C++ code for backslash. It has nothing to do with any OS, it's just a way to allow backslashes when backslashes are defined by the language as an escape character.
I know this is nit picky, but the syntax has nothing to do with the platform.
Robbiem01
wow I found the anwser without making my own thread for once! Now I just need a little more help with deleting files. In my program I let the user pick the name of the file and store it int char array [30];. How can I delete this file later. I dont know the exact c: path because the file is created in the same folder as where the program is executed. Any help would be greatly appreciated!
