Like the others what went wrong and with what delidding tool?In a twist of sad irony, our very own maddmutt just killed one using the tool.
Still worth doing as that is not common with a tool, but found it worth posting if only for the timing.![]()
Thanks for the advice ....There are quite a few decent 240mm AIO/CLC coolers.
Cooler master ml240l is a good one.
EVGA 240mm CLC is too.
You can also look into the Corsair H100i.
They are all good units and will cool within a few degrees of each other.
I would be interested in knowning where madmut went wrong with this tool delid. Seems pretty fool proof to me if you pay attention to what you are doing and put the chip in the correct way.
The stock IHS is nickel plated copper. You will gain little or nothing temp wise changing that to full copper.
That all copper ihs also has more surface area than the factory ihs. Reviews show a few C difference.
https://www.gamersnexus.net/guides/3238-custom-copper-ihs-tested-on-intel-i7-8700k-cpu-rockit-cool
