- May 12, 2015
Ive done delids before, but that was on athlon 64's. This is no different, used a razorblade got the IHS off, use my finger nail and got the old black stuff off the cpu pcb, and the IHS.. cleaned the core and ihs inside and out, put new thermal paste on the core, dropped the cpu in the socket. then IHS.. held the IHS centered so it wouldnt move.. Put the clamp on, put paste on the IHS, and the waterblock back on.. Temps at idle seem lower then before in the upper 20's. Like 28c, but on load using cinebench the cpu got to 92c to where prior it only saw about 70c, in warhammer total war 2 the cpu saw 67c, where it barely broke 57c prior.
Not sure what the issue was, i took the block off, the block spread the paste evently and thinnly no raised spots or blobs so there is good surface contact. I took the IHS off, same thing. The entire core is touching the IHS the paste is so thin you can see through it so there is no contact issues from what i can see anyway..
Why are the temps so much higher.. I mean damn, if i knew it was going to do this i would kept the damn thing on lol
