I don’t think you are not going to be able to upgrade that system without switching out the PSU as well. Dell has special proprietary connections between the MOBO and PSU.
I have an asus p4c800-e deluxe and my folks have a dell their home. I've worked a little on the dell system and I I'm _pretty_ sure (not certain) that the dimensions were very similar (mobo being same sizes). Hope this helps at least a little.
The wiring for the front panel connector is non-standard. Dell use a ribbon for the front panel connector with unique pin assignments. The motherboard looks to be a cross between a MATX and an ATX motherboard. You need to mod the back of the case to accept a standard ATX powersupply.
You know it might be worth it to get a new case considering how goofy dell's stuff is. Unless you wanna have a bad assed custom computer in a Dell case... I always thought that would be neat - otherwise I would find a cheap case from newegg or directron.
