Dell Dimension Overclocking?!!?!?!?
Xplos!ve
Florida, USA
Hi, i have found an old Dell Dimension lying around and decided 2 overclock it as i never have overclocked a pc before but its really old and i dont know wether its possible 2 overclock its a Dell dimension p100t (a pentium 100mhz) with 32mb ram ive went into the bios and cant find where to change the fsb voltage etc so i thought its not possible 2 overclock can any1 tell me if it can? i dont know anything about this pc than i have already told u sorry
Avg
Senior Member
I've seen another post about this before, and they said it wasn't possible
ChillPhatCat
Ballston Spa, NY
Waaaay back in the day I overclocked my P120 to 133MHz... little did I know that I had been originally sold a P100 under false pretenses... I figured this all out about 4 years after purchasing the comp... so I didn't really care.
Getting back on track, with that and other P1 chips I've found that P75-P133 chips run in that range as long as the temps are kept down and P150+ run 150~233 MHz depending on mobo...
Seeing how motherboards were set up back then I would bet that you could run that P100 @ 133 just by flipping the dip switches correctly... most of those old name brand comps (socket 7) had dip switches to control multiplier and FSB... multis from 1-3 and FSB 60 or 66 selectable...
Another thing you might check with something that old is upgrading the on-board L2 cache from the standard 256k to 512k or 1Mb... When I doubled my L2 I saw a very big improvement.
fhanderson
Parma, OH
I put a Pentium 200mmx in A Dell P133S and I had to change the jumpers for the new processor. I would try changing the jumpers for the next higher fsb or the next higher mhz processor. Yo can try adding a cooling fan to the heatsink if you have a passive one.
X
Xplos!ve
Florida, USA
thx for all the info lads i will be trying it out as soon as i get my HDD back off my uncle :( *sigh* (ill be waiting a while) but anyways i shall try all that once again thx btw i have found an old pentium 2 200mhz but its a slot 7 and the pentium 100mhz is a slot 5 :( nm thx
X
Xplos!ve
Florida, USA
i have never actually overclocked before so i actually havent got a clue wot im doing i know i have 2 go into the bios and change aload of stuff but can any1 tell me wot i actually do?
