- Sep 24, 2001
- Currently Nowhere
The motherboard on a friend's Dell Dimension 4600 went bad and Dell wants $159 to send him a new motherboard or $275 to send someone to replace it--HA!(it's out of warrantee). So, I told him I'd pitch the box and salvage all the parts including the memory and CPU and spend a lot less than $159 to get it up and running again. I would just get a new case and mobo--and perhaps a new HSF as well.
I go to Dell's website and enter the "Service Tag" number to get all the configuration information for this PC (a listing of the components) only to find that the site doesn't work.
So, I get the memory out easily enough:
2 X Infineon 128 MB DDR400, CL3
PC32000-30330-C0
Finally, after soaking the heat sink in Goof Off, I manage to pry off the P4 without damaging anything.
Intel Pentium 4
2.40GHZ/512/533
SL6PC CHINA
5329A860
93338394
0517
This is basically a backup desktop system for business use and we're not all that interested in overclocking it (well, not at this time anyway). We're just looking for a very stable but cheap board. Preferrably, we're looking for a mini-atx size board with integrated LAN. We can still use the AGP video and PCI Fax/Modem and Soundblaster card that the original machine came with. We would, however, like to upgrade the system memory to 512 MB and use the existing memory if possible. He wants a brand new motherboard with a manufacturer's warrantee.
I also have a question about the Dell PSU. I remember a while back that Dell wasn't using standard wiring and that you could burn out a board using a Dell PSU on a standard board (or visa versa). I compared the wiring on a standard PSU and noticed that the standard PSU has a white lead (about pin 5) and the Dell PSU is empty at that spot. All the other colors match up however. (I didn't actually take my multimeter to each lead to compare voltages when they were plugged in and running.) Am I safe using this Dell PSU with whatever new mobo we get--assuming it isn't grossly underpowered?
PC32000-30330-C0
Intel Pentium 4
2.40GHZ/512/533
SL6PC CHINA
5329A860
93338394
0517
