T5400 memory fan -- is this diagram correct?
I'm simply trying to replace the Dell T5400 memory fan (I think this is what you called 'hard drive cooling fan') with a larger Noctua fan to reduce the noise level. I bought a third-party Dell fan conversion cable and the new fan runs when powered up, but the bios reports a fan error -- probably because the wiring is substituted incorrectly or maybe there is a voltage issue.
I sure would love to make this work, but my knowledge is very limited when it comes to electrical. I checked the conversion cable, and it does appear that the substitutions follow the diagram shown here. Your post suggests that not all standard fans would follow this chart.
Are you able to shed light? Many, many thanks.
Just bear in mind that not all Dell Delta fans are the same PWM setup. There are a handful out there that have the appropriately colored wires, but arent PWM, or arent standard PWM. I have 2 AFB1212s from a Dell T5400 used as a hard drive cooling fan and they did not work through PWM control at least through the motherboard's output. They may have been a different voltage or reverse PWM, I dont know.
