cjtune (Jul 31, 2001 05:38 a.m.):
AmbientFiction (Jul 30, 2001 11:16 p.m.):
It would work all its doing is pushing twice the air on to the heatsink I don't see any compitation air wise unless its the fact that you need more air flow comeing into the case. Like say an open 5 1/2" drive bay the lowest one you have or in line with the cpu and take a hard drive cooler install it and turn that sucker on. that would give the air flow that you need.
Axial fans produce seriously less airflow with increasing impedence to the airflow path. Note that both of your fans need to push (together) twice the amount of air through an exit 1/2 as big as with just one fan alone. By itself, one fan on your HS may output 20cfm, but together in your configuration they may just output 12+12=24cfm -diminishing returns for parallel flow. This is why some ppl consider stacking fans to produce more pressure (in series config) to fight the impedences, but this stacking cannot be realistically done on the normal DC fans we use, one on top of another, due to the direction of rotation and blade design -in essence, the two fans
must be designed for each other.
Do you have any temperature measurements to test out your fan placement method?
