- Jun 28, 2012
you are really good at that.... >.> butte.
captain almost making me buy a bunch of 3tb drives yesterday.
and the monitor you made me buy a few months ago.
thisiswhyimbroke.user
I'm just getting warmed up!
Thanks! I bumped up the bottom monitors a notch so they can slide back over the speakers, which gives me a ton more space.You're going to need a bigger desk soon Thiddy.Nice set up.
I think the drooling is coming from your side of the monitor.Might want to wipe down the monitors and get the water off.![]()
Ha ha maybe, I'm still slumming it with 1 24" U2414h and 3 22" Acers from 08 in quad.I think the drooling is coming from your side of the monitor.![]()
I searched all three pages of this thread and could not find the model number for those monitors.
Can this information be revealed?![]()
Sorry!I searched all three pages of this thread and could not find the model number for those monitors.
Sorry!
Austin is right, and I added the details to a previous post.
Thanks!Love your Overkill builds! Keep it up![]()
We can all look on in awe and get some inspiration.Love your Overkill builds! Keep it up![]()
I have no idea if they are the same series. Dell calls them both Ultrasharp. Key points for me are IPS, thin bezels and 1200 pixels vertical resolution. Coming from 1600x1200 I'm just not ready to lose vertical resolution and so many of the monitors in that class are FHD - 1920x1080. Now I'm wrestling with what to do for connections (with a KVM complicating matters.)If those are the same series as mine, you will love them.
