wattage=current*voltage
Electrical power is measured in watts. In an electrical system power (P) is equal to the voltage multiplied by the current.
P = VI
The water analogy still applies. Take a hose and point it at a waterwheel like the ones that were used to turn grinding stones in watermills. You can increase the power generated by the waterwheel in two ways. If you increase the pressure of the water coming out of the hose, it hits the waterwheel with a lot more force and the wheel turns faster, generating more power. If you increase the flow rate, the waterwheel turns faster because of the weight of the extra water hitting it.
In an electrical system, increasing either the current or the voltage will result in higher power. Let's say you have a system with a 6-volt light bulb hooked up to a 6-volt battery. The power output of the light bulb is 100 watts. Using the equation above, we can calculate how much current in amps would be required to get 100 watts out of this 6-volt bulb.
You know that P = 100 W, and V = 6 V. So you can rearrange the equation to solve for I and substitute in the numbers.
I = P/V = 100 W / 6 V = 16.66 amps
What would happen if you use a 12-volt battery and a 12-volt light bulb to get 100 watts of power?
100 W / 12 V = 8.33 amps
So this system produces the same power, but with half the current.
P=VI and PIV=SUX
