- Mar 11, 2001
- Auburn California
tried the new drivers and ended up with a 94 point gain in 2001 over the 12.40's just thought id share.
outhouse (Jun 16, 2001 09:33 p.m.):
I DONT BELIEVE IT!
i just overclocked my VC to 240\219 ran 2001 and ended up with 4036! i thought maybe i would be lucky to get to 3000 but 4036 almost doubled my score when it was not overclocked, i'm pretty happy about this to say the least![]()
one note i did change a few things in the settings on 2001 so this may have helped my scores i guess i should recheck using default settings
how do most of you run 2001 at default or do you set it to match your system?
Do you mean 3Dmark2001? Usually the score in 2000 goes down when using the later drivers.batboy (Jun 17, 2001 05:22 p.m.):
Ok, you guys inspired me to try the 12.60 drivers. Prior to this, my best benchmarks with 3Dmark2000 were with the 12.40 drivers. Yippee! The new Detonator 12.60 drivers netted me another 78 points better than the 12.40 drivers (using identical settings in both cases).
