Detonator RIP and Destroyer doesn't work, please help !
Zephon
Malaysia
Hi all,
I need a software which can completely remove my old nVidia driver. As ppl suggest I had try the Detonator Destroyer and Detonator RIP, both are not working for me. The Detonator seems doesn't support windows XP, and the Detonator RIP show error massege when I try to run it :
"The applicatoin failed to initialize properly... ..."
So, is that any other way which can let me perform the same task? PLease help me, Thanks.
Heed this note regarding Detonator R.I.P. under XP:
NOTE: This utility should work on almost all Windows versions including Win98, Me, XP,2000. You will require the .NET framework to be installed on your PC. If you don't have it, you can download it from here.
