Perhaps they thought we wouldn't care if we paid $50 for an underdeveloped game.
Pros:
1. Deus Ex's interactive world (i.e. pick-up/move furniture, open containers).
2. Deus Ex's Biomod upgrade system.
Cons:
1. 18 fps out of the box (on 640 x 480 resolution) on a 2.0+ GHz/1GB pc3200/9700pro system.
2. I actually had to TWEAK the default.ini file to get the game to run smooth enough to see that I was in a room and not watching a slideshow.
3. The game is a DIRECT port from the X-Box. There is even a Vibrate check-box in the game options menu (people may tell me that's for those of you who use a gamepad, but that's around .000006% of gamers, so you know it's from the X-Box menu).
4. The biggest problem in my opinion: The Save and Load features. This game has the WORST save and load system than I have seen in YEARS. First off, there is no quicksave/quickload. This in and of itself is unacceptable for DEUS EX 2. I mean, the whole point of Deus Ex is that you quicksave/quickload for multiple options in dialog/actions! Secondly, if you DO try to save before every option in the game (i.e. dialog, opening a locker, etc...) and then try to load that save, the loading takes at LEAST a minute and a half. This would be alright if I were running a sub-par machine. Not only am I using the machine listed in number 1, I also have a pair of Raptors in RAID 0 and am using the FULL INSTALL of the game. It takes almost 3 WHOLE MINUTES to get from my DESKTOP to when my save game has completely LOADED. In my opinion, the save/load features of this game are enough to make me want to go back to Best Buy and beg for them to give me ANYTHING to take it back. The game is un-playable (if you want to have fun) in its current state.
5. I can't run the game in anything above 640 x 480 (800 x 600 in some small areas) without an EXTREME loss of performance (we're talking running at 5 - 6 fps) as noted in number 1. Because of this, the heads-up display takes up a good 1/3 of the playing screen. 33% taken up by something that could easily have been hidden at the push of a (now non-existant) button. This is an obvious result of the quick X-Box to PC port.
6. The game has been "dumbed down" to allow 8 - 10 year olds to play and understand the game. I have had multiple conversations that follow the guidelines of:
Alex D: How do I pass the wall?
Random: You could either blow it up, climb it, or find another way around it.
Alex D: Thanks!
Pathetic.
7. The original open-ended play and "feel" of the original is, to put it simply, absent from the game. They have catered to the X-Box crowd, not the PC.
Synopsis:
Do not purchase this game unless there have been patches released that deal with the above problems. The gameplay potential is there (albiet without the original Deus Ex feel as it feels like a CHROME knock-off) but the technical problems stand in the way of an enjoyable gaming experience. This is NOT the sequel that so many people have been waiting for. This is, in my opinion, a stand-alone game created in the same fictional world as the original Deus Ex, but is NOT Deus Ex 2.
The "feel" of the original has been lost.
*Edit* - Grammar and other, similar, non-essential things.
Pros:
Cons:
Alex D: Thanks!
Pathetic.
Synopsis:
