- Apr 12, 2003
- Middlesbrough
Hi all thought i would post all my settings for any compares
Under advanced chipset features
Thermal throttling Disable
Errata 94 Disable
Genie bios setting / Dram Configuration
Mhz 200 1:01
Cpc Auto
Tlc 2.5
Trcd 04
Tras 07
Trp 03
Trc 07
Trfc14
Trrd 02
Twr 02
Twtr 01
Twt 02
Tres 4708 cycles
Twcl 05
Dram bank interleave Enabled
Dqs skew control Increase skew
Dqs Skew valve 0
Dram drive strength level 6
Dram data level 4
Max async Auto
Preamble Auto
Idle cycle 256 cycles
R/W queue bypass 16x
bypass Max 07x
32 Byte disable 8 burst
Genie bios setting
Fsb 302
Ldt/Fsb Auto
Ldt bus 16 16
Cpu/Fsb x9.0
Pci express 100 Mhz
k8 cool Disable
Cpu start up value 1.500v
Cpu vid control 1.500v
Cpu vid special above vid x 104%
Ldt voltage 1.30v
Chipset voltage 1.7v
Dram voltage 2.9v
I think thats about it oh one more thing
Cpu vid control is the v core
cpu vid special control is vcore x the percentage..
so you set cpu vid control to 1.45v and special to 113% the vcore would be 1.63v
Cheers andy
hope it helps anyone out
Errata 94 Disable
Mhz 200 1:01
Cpc Auto
Tlc 2.5
Trcd 04
Tras 07
Trp 03
Trc 07
Trfc14
Trrd 02
Twr 02
Twtr 01
Twt 02
Tres 4708 cycles
Twcl 05
Dqs Skew valve 0
Dram data level 4
Max async Auto
Preamble Auto
bypass Max 07x
Genie bios setting
Fsb 302
Ldt/Fsb Auto
Ldt bus 16 16
Cpu/Fsb x9.0
Pci express 100 Mhz
k8 cool Disable
Ldt voltage 1.30v
Dram voltage 2.9v
Cheers andy
