- Jan 12, 2004
- Menthol Island
DFI Alpha Setting
bus#0 dev#0 func#1 0ffset#94,95,96,97
if u want to check alpha setting with WPCREDIT plz change it to 32bit mode.....
from left to right :-
- T(DOE) : Selectable Value: 0,1,2,3,4,5,6
- T(RRD) : Selectable Value: 0,1,2,3,4,5,6
- T(W2P) : Selectable Value: 0,1,2,3,4,5,6
- T(W2R) : Selectable Value: 0,1,2,3,4,5,6
- T(REXT) : Selectable Value: 0,1,2,3
- T(R2P) : Selectable Value: 0,1,2,3,4,5,6
- T(R2W): Selectable Value: 0,1,2,3,4,5,6
- Reserved : always 0
try loosen it to 2-3-3-3-3-3-4... or even loosen.. u will gain more stable FSB... no performance hit.. dont worry
here is other register if u want to do further tweaking...
Happy Tweaking & Overclocking ....
cheers,
tictac
Code:
* nVidia nForce2 Data Base *
1) AGP Controller Latency
PCI Bus#0 Dev#30 Func#0 Offset#0D
0D
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
2) AGP Bus Latency
PCI Bus#0 Dev#30 Func#0 Offset#1B
1B
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
3) PCI Latency
PCI Bus#0 Dev#8 Func#0 Offset#1B
1B
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
4) CPU Disconnect Function
PCI Bus#0 Dev#0 Func#0 Offset#6C,6D,6E,6F
6C 6D 6E 6F
- Enable : 01 FF 01 1F/9F
- Disable : 01 FF 01 8F
5) Command Per Clock (T1/T2)
PCI Bus#0 Dev#0 Func#1 Offset#84,85,86,87
84 85 86 87
- Enable : F3 13 0F 03
- Disable : F3 13 0F 23
WARNING! (Not Editable after boot, Can only be set before memory sizing)
6) Alpha Memory Setting
PCI Bus#0 Dev#0 Func#1 Offset#94,95,96,97
94 95 96 97
- T(DOE) : x Selectable Value: 0,1,2,3,4,5,6
- T(RRD) : x Selectable Value: 0,1,2,3,4,5,6
- T(W2P) : x Selectable Value: 0,1,2,3,4,5,6
- T(W2R) : x Selectable Value: 0,1,2,3,4,5,6
- T(REXT) : x Selectable Value: 0,1,2,3
- T(R2P) : x Selectable Value: 0,1,2,3,4,5,6
- T(R2W) : x Selectable Value: 0,1,2,3,4,5,6
- reserved: - Selectable Value: -
- Offset 94 = XY
X= T(R2W) Selectable Value: 0,1,2,3,4,5,6
Y= Reserved -
- Offset 95 = XY
X= T(REXT) Selectable Value: 0,1,2,3,
Y= T(R2P) Selectable Value: 0,1,2,3,4,5,6
- Offset 96 = XY
X= T(W2P) Selectable Value: 0,1,2,3,4,5,6
Y= T(W2R) Selectable Value: 0,1,2,3,4,5,6
- Offset 97 = XY
X= T(DOE) Selectable Value: 0,1,2,3,4,5,6
Y= T(RRD) Selectable Value: 0,1,2,3,4,5,6
7) Normal Memory Setting
PCI Bus# Dev# Func# Offset#
- T(RAS) :
- T(RCD-Read) :
- T(RCD-Write) :
- T(RP) :
- CAS Latency :
- T(RC) :
- T(RFC) :
8) Side Band Addressing
PCI Bus#0 Dev#0 Func#0 Offset#49
49
- Enable : 03
- Disable : 01
cheers,
tictac
