- Dec 14, 2010
I've got this rather annoying problem with my DFI LP UT nF4 SLI-DR Expert (model name is a mouth full, isn't it?).
Anyway, when I'm benching on it I'm running into issues with overheating on one or two of the PWM/VRM/mosfet heatsinks and one or two of the chokes. Not sure why I would be having these issues, since I have a fan right directly above that area of the board.
It seems like it takes a while for it to heat up to the point where it becomes a problem and ultimately causes instability and/or a lockup, or shutdown/blue screen. It was happening fairly quickly before, then I switched out my exhaust fan for a model with a higher RPM and more airflow (switched a Yate Loon D12SM-12 (70CFM) out for a Cooler Master Excalibur (~90CFM)) and after that the system took longer to overheat but it still does though now it just takes a little longer.
At the moment I'm pushing 1.57-1.58V to a dual core CPU (Athlon 64 X2 4200+ Manchester (E4)) to keep it at or around 2.8GHz (stock 2.2GHz). I can drop it down to around 1.45-1.46V for 2.7GHz and then it doesn't overheat, but I need the extra 100MHz to remain somewhat competitive in the benchmark ratings (actually I'd like to push the frequency up higher, if I could get it to stop overheating first).
Problem is, the parts that are overheating are in an area that is difficult to get to, and would be nigh on impossible to mount a fan on while it is in a case. So, that option is out. That was my first choice, but after looking at it I don't think it will be an option, and if I could do that it would have to be with the case lying on its side and in that scenario the case airflow would not be as good as it is when the case is upright.
Unless I'm missing something, I fear I may have to pull my system out of the case and run it on an open-air test bench to get it to stop overheating. I'd rather avoid that if I can, since I don't have a proper test bench station to mount it to and can't really afford for one at the moment.
Has anyone else run into similar issues?
