DFI P45 T2RS Overclock Problems
TDubbs05
Flagstaff, AZ
Recently, my DFI T2RS has been acting up whenever I try to oc my e8400. I've gotten the e8400 to 3.8 ghz and stable before but now it won't boot whenever the e8400 is even slightly oced. Every time I change my clocks, I have to reset the CMOS to get it to boot again. I've reset my e8400 back to it's stock clocks which seems to have helped, but I want/have to get this thing oced again. One thing I have noticed at that my NB temps are through the roof even at stock voltages/clocks; it'll idle at 59 C. I'm sure this temp might be one of the culprits, but before I tear everything apart and repaste the mobo heatsinks, I wanted to see if anyone else has run into these problems. All of my bios settings are based on the http://www.ocforums.com/showthread.php?t=575147 thread. Please let me know if anyone has ran into similar problems. At at this point I'm about ready to go out and get a TPower or P5Q P45 and call it quits.
Thanks in advance.
redduc900
Inactive Moderator
Portland, OR
Fill out this BIOS template for the DK P45-T2RS w/ all of the settings used for 3.8GHz (disregard the settings in the template, and replace w/ your own). Also post a direct link to your RAM showing SPD timings and default voltage. And what program are using to read the NB temp., or are you reading the Chipset Temp. from the PC Health Status screen in the BIOS? At a FSB of only 420MHz, vNB shouldn't need to be increased past the default of 1.2V unless you're running 4 sticks of RAM. So take NB Core Voltage off AUTO, and manually set it to 1.2V (after a save and reboot, recheck the vNB in the PC Health Status.)
Code:
Genie BIOS Page	BIOS Field
	Exit Setup Shutdown……Mode 2
	Shutdown After AC Loss……Enabled
	AC Shutdown Free……Enabled
	OC Fail Retry Counter……1
	OC Fail CMOS Reload……Disabled
	CPU Clock Ratio……9x
	CPU N/2 Ratio……Enabled
	Target CPU Clock……4194 MHz
	CPU Clock……466
	Boot Up Clock……	Auto
	CPU Clock Amplitude……800mV
	CPU Clock0 Skew……0ps
	CPU Clock1 Skew……0ps
	DRAM Speed……333/800
	Target DRAM Speed……DDR2 1119
	PCIE Clock……100 MHz
	CPU Spread Spectrum……Disabled
	PCIE Spread Spectrum……Disabled
CPU Feature Page
	Thermal Management Control……Enabled
	PPM (EIST) Mode……Disabled
	Limit CPUID MaxVal……Disabled
	C1E Function……Disabled
	Execute Disable Bit……Disabled
	Virtualization Technology……Disabled
	Core Multi Processing……Enabled
DRAM Timing
	Enhance Data Transmitting……Normal
	Enhance Addressing……Normal
	T2 Dispatch……Disabled
	Flex Memory Mode……Auto
	Cas Latnecy Time (tCL)……5
	RAS# to CAS# Delay (tCRD)……5
	RAS# Precharge Time (tRP)……5
	Precharge Delay (tRAS)……15
	All Precharge to Act……Auto
	REF to ACT Delay (tRFC)……Auto
	Performance LVL (Read Delay)……Auto
	Read delay phase adjust……N/A
	Write to PRE Delay (tWR)……Auto
	Rank Write to Read (tWTR)……Auto
	ACT to ACT Delay (tRRD)……Auto
	Read to Write Delay (tRDWR)……Auto
	Ranks Write to Write (tWRWR)……Auto
	Ranks Write to Read (tWRRD)……Auto
	Read CAS# Precharge (tRTP)……Auto
	All PRE to Refresh……Auto
Clock Setting Fine Delay
	DLL and RCOMP Settings……By Menu
	CH1 DRAM Default Skew……Model 3
	CH2 DRAM Default Skew……Model 3
	RCOMP Setting…Model 1
	Fine Delay Step Degree……70ps
	Ch1 Clock Crossing Setting……Nominal
	DIMM1 Clock Fine Delay……1346ps
	DIMM2 Clock Fine Delay……1346ps
	Ch1 Control0 Fine Delay……166ps
	Ch1 Control1 Fine Delay……166ps
	Ch1 Control2 Fine Delay……124ps
	Ch1 Control3 Fine Delay……110ps
	Ch1 Command Fine Delay……262ps
	Ch2 Clock Crossing Setting……Nominal
	DIMM3 Clock Fine Delay……1346ps
	DIMM4 Clock Fine Delay……1346ps
	Ch2 Control0 Fine Delay……14ps
	Ch2 Control1 Fine Delay……56ps
	Ch2 Control2 Fine Delay……0ps
	Ch2 Control3 Fine Delay……0ps
	Ch2 Command Fine Delay……110ps
	Ch1Ch2 Common Clock Setting……Nominal
	Ch1 RDCAS GNT-Chip Delay……Auto
	Ch1 WRCAS GNT-Chip Delay……Auto
	Ch1 Command to CS Delay……Auto
	Ch2 RDCAS GNT-Chip Delay…Auto
	Ch2 WRCAS GNT-Chip Delay……Auto
	Ch2 Command to CS Delay……Auto
Read Delay Phase Adjust
	Ch1 Read Delay Phase (4~0)……8-8-8-8-7
	Channel 1 Phase 0 Pull-in……Auto
	Channel 1 Phase 1 Pull-in……Auto
	Channel 1 Phase 2 Pull-in……Auto
	Channel 1 Phase 3 Pull-in……Auto
	Ch2 Read Delay Phase (4~0)……8-8-8-8-7
	Channel 2 Phase 0 Pull-in……Auto
	Channel 2 Phase 1 Pull-in……Auto
	Channel 2 Phase 2 Pull-in……Auto
	Channel 2 Phase 3 Pull-in……Auto
Voltage Settings
	CPU VID Special Add……+187.5mV
	DRAM Voltage Control……2.100V
	SB Core/CPU PLL Voltage……1.55V
	NB Core Voltage……1.3825
	CPU VTT Voltage……1.20V
	Vcore Droop Control……Enabled
	Clockgen Voltage Control……3.45V
	CPU GTL 0/2 REF Volt……0.67x
	CPU GTL 1/3 REF Volt……0.67x
	North Bridge GTL Ref Volt……0.58x
	FSB Vref……Auto
