- Dec 25, 2004
Current setup is 4 cards, 3 1080 Tis and 1 plain 1080. 2 power supplies.
I used to have separate UPSs on the PSUs, but I've switched over to one UPS, and swapped which PSU was supplying the motherboard, as the connecter was heating up.
System seems a bit more stable now too.
I did have a 1080 Ti card that went back to EVGA about a year back and was replaced. I still couldn't get it to work in my system, but I figured it was probably my system, and not the card.
So, since the system was behaving better, I'd see if the card would work, so I swapped out the plain 1080 for the RMA replacement Ti card.
It worked for a day or so (mostly) then kept having problems with the system. So I put the plain 1080 back in, and system is stable.
I also have a computer in my garage running 2 1080 Ti cards with no issues.
So....Here is my plan.
Pull one of the 1080 Ti cards from the garage system and replace it with the potentially questionable card. Give it a week or so and verify if it works there or not. If it does, leave it there.
Use the card pulled from the garage system to replace the 1080 plain card in my main computer. See if it works there. If it does, just leave it alone. If it does not, swap out the PSU that was scorching the motherboard power connections with a new PSU and try again.
Both PSUs are Corsairs of the same model and are 1000W each. I'm confident that they aren't having a problem because they are undersized.
Does this seem like a reasonable troubleshooting path?
Thanks!
Thanks!
