Maybe someone can help me. I just installed my first water cool system on my computer and it is turning into a disaster. I hooked everything up (dangerden waterblocks) and a homemade radiator. I let it run for about 8 hours and it worked flawlessly!! Next I install it in my machine and get everything properly tightened and hoses run and hose clamps installed. Then I run the system for about an hour with out the pc being hooked up just to make sure and again everything worked out fine. So I fire up my system and the thing sez I have a corrupt cmos and that default are being set. So this is weird but I reset everything and reboot and the machine starts the boot process but doesn’t load after the point when you would normally see the windows logo screen pop up. It just sits there and the monitor goes to no input signal. I reboot and set the settings to a speed that I know will work but I still get the same thing!!. I don’t know what else to do! there are no leaks and I used a static wrist strap the whole time I worked on it. The cooling system works real well cause I can get into the bios and see temps and it is running like 30c this is not on-die but that is way better that I was doing before. ANY IDEAS will greatly be appreciated.
P.S.The box is the same one that is in my sig and I have waterblocks for the CPU and GPU
