- Jan 8, 2002
- Boulder CO
Yesterday I went over to homedepot and picked up a bunch of stuff. This is my first time i ever modded my pc and i would like to do it correctly.
1 89mm Hole Saw (for 2 92mm fans i will be attaching)
1 76mm hole saw (for 3 80mm fans i will be attaching)
a 3/8 " (9.53mm) Hole Saw Mandrel So I can attach the hole saw to a drill
A 7.2V MultiPro Cordelss 7700 Dremel. Runs top speed at 15,000 rpm
A Dremel Cut off whell set with 69 pieces
Saftey Glasses
Some arcillic lucite plexy glass
Basically what i want to do with my pc is on one side where i allready have a window (i purchased the lianli pc65 window for $30) i would like to mount 2 92mm fans over my pci cards. Then on the top of my case, i would like to mount 3 80mm ehaust fans.
On the right side of my case i want to carve into the metal with my dremel the flame on my avatar. After this is done I will connect it using some artic silver epoxy that i have laying around.
I heard somebody say something about some kind of oil that i need in a different thread. What kind of oil is this and is it really necessary?
Saftey Glasses
