I tried installing XPPro on a IBM Deskstar 30GB 7200 ATA HDD, and I thought the HDD had problems. The os was fully installed the first time but then started crashing so I tried to install it again, and I had to tre-try copying files over and over with enter key just trying.
then error "A problem has been detected and windows has been shut down to prevent damage to your computer"....disable cache or shadowing
*** STOP 0x0000008E(... " screen
Then after re-installing yet again and I couldn't even format the HDD. 99%....Setup is unable to format the partition. Fixed any jumper problems.
Then I get 5 boots in a row with 5 errors as follows:
1 ntkrnlmp.exe cannot be loaded
2 file ql12160 is corrupted
3 file sbpport.sys is corrupted
4 unkown BIOS error Error code=FFFF
5 STOP blue screen text STOP....
I thought the HDD was dead. aLL PARTS WERE APART but I had JUST RE-AASEMBLED EVERYTHING (CORRECTLY i ASSUME). whoops. Its a $250 Asus mobo & I JUST bought a NEW XPPro disk for it and all else (this (newly re-planned for wi-fi family use) P4 2.6C cost me over a grand just a few ago)! .
I put the HDD in another pooter and it formatted fine (& installed) win2kPro. So I put the HDD back in the pooter I want to install xpPro on and it was telling me cannot find P4C800ED.ROM (begging for the CD drive) & beeping like crazy "BAD BIOS checksum"
So I found the ORIGINAL BIOS app CD disk quickly and it found its file it was screaming for and re-FLASHED the BIOS - by itself (like last chance before death)!!!. Told me to power down and re-start. No, but it was not the same BIOS. But the BIOS on the disk was old I had updated it since then. DEAD.
So it went from a dead HDD to a desperate BIOS flash to ... nothing on screen (blackness) and a spinning cpu fan but no spinning FX5900 vid card fan.
What did I do. What can I do? btw is BSOD black or blue & empty or text? Can I short pins. Help. Knowledge pls.
