- Aug 11, 2002
- albuquerque
I ask because I found a post in hardocp's forum from someone besides myself that recieved their "new" board and found that one of the onboard switches (power switch) was damaged they also mentioned where it was purchased (zzf) the post should be here
http://www.hardforum.com/showthread.php?t=871266
From the post it appears that they proceeded to use the board in spite of the damaged switch. My ultra which arrived last week from newegg was similarly damaged I noticed it because after I removed the board from antistatic bag I heard something rattling in it. Upon close inspection I found a little piece of metal and some plastic. After several slaps and some shaking of the board I found another little piece of metal and then a tiny metal spring that was caught on or under one of boards components. I also have decided to keep this board as an rma will result in additional cost and more than likely result in me getting the unmoddable revision. I thought I would mention it if it turns out to be something others might encounter. I should that I tore apart an identicle switch (the reset button on the front panel of a case) so I could be certain there wasn't something else that might be caught on the board that might "smoke it" the minute I turn it on. If you find that your board's onboard switch's are not there or you find pieces in the bag and you can live without this "feature" Make certain you FIND THESE FOUR PARTS the spring, and the two small copper contacts and I forgot the small metal hook looks sorta like this (_] the first ones were attached to the plastic button the hook is attached to the part of the switch that should be still on the board but I doubt it would stay there examine the board from every angle give some light pats and if you powered it up before finding the damage and have had any problems rma pdq if you are not having issues but kept a damaged board find those suckers they are all very small.
