- Feb 26, 2006
- Barnegat, NJ
Whats the difference between the Xteme Music, Fata1ty, platinum, and the elite cards?
jivetrky said:Xtreme music is just base card (which is just fine for most people)
Platinum is Xtreme Music card with front IO panel
Fatailty is like a platinum but it has 64MB of XRAM (which can help performance in some games if they are programmed to use it. (Like BF2 [probably BF2142 too], Quake 4, probably a few other games)
Elite has an external box with several knobbie things (IDK what each does) And the DAC is much better than the other X-fi's, and a few other things like higher SNR, etc.
nd4spdbh2 said:its BAD when your sound card needs a friggin heatsink lol. freakin fatality crap.
I had a question on these x-fi cards. They are all 7.1 have a mic in and a line in, but they only have 4 of the circle connectors. To have 7.1, mic in, and line in, dont you need 7 connectors?
So you can't do 7.1 and have a mic? Also, is there front panel support besides the front panel they offer? Will you be able to hook the card up to your case front panel?
pak said:So you can't do 7.1 and have a mic? Also, is there front panel support besides the front panel they offer? Will you be able to hook the card up to your case front panel?
--pak
Rest of Card
1 - Analog Ground
2 - Analog Headphone Out Left
3 - Audio Backpanel Mute -- short to ground to mute the backpanel (when headphones are plugged in)
4 - Analog Headphone Out Right
5 - same as #3
6 - Mic input from front panel
7 - No Connection
8 - VREF out -- voltage reference for Mic
9 - MIC IN MUTE -- ground when mic isn't plugged in, +12VDC when mic is plugged in
10 - Audio cable detect -- will be ground when headphones are plugged in (not normally used)
Slot pointing outside your PC
Sir Barton said:If youre hooking your X-Fi to a home theater receiver youre better off using the analog connections instead of the digital. If youre using digital, you will only get stereo sound unless youre listening to something already encoded in Dolby.
pak said:Aren't those these? http://us.creative.com/products/product.asp?category=1&subcategory=16&product=14309 That were mentioned before?
--pak
