Difference between X800 and X800 XT and Pro
Miller12
Aurora, IL.
Does anyone know what the difference is between the x800, x800 xt and the x800 Pro, I am planning on purchasing a X800 Xt. :confused:
bigswede2
Sweden
xt has 16 piplines, pro & x800 have 12 pro has higher core rates then the normal x800 but less than xt so if you can afford iy the xt is the best bet,
Docta_Z
Canada
erm.
I'm fairly certain there is no such thing as a plain X800. The only models are the pro and the XT... in north america at least...
Like he said, XT has 16 graphic pipelines and slightly higher clock rates then the pro (although some pros can overclock just as far if not further)
bobmanfoo
Disabled
Docta_Z said:
erm.
there will be an x800se
Nightingale
Ohio
I guess the difference between the XT and XT PE are that PE has slightly higher clocks on the mem and core.
Nightingale
Ohio
Thats what I thought but if you look at the X300-X800 sticky they show the Xt running at 500 on the core and the pe running 520 on the core. I can't confirm they really are to seperate cards but thats what I am getting. Guess you could always check the specs on the ATI website or something.
Dc5e
MA
i believe the XT is PCI-E and the XT PE is PCI-E/AGP or something
OBLIVIONLORD
Anandtech.com has 3 versions for Agp:
ATI Radeon X800 Pro: 12 pipes, 475 core, 900 mem
ATI Radeon X800 XT: 16 pipes, 500 core, 1000 mem
ATI Radeon X800 XT Platinum Edition: 16 pipes, 520 core, 1120 mem
