Differences among these 3 Intel X25-M G2's?
jwwpua
They're all from wiredzone.com (and other places I've seen like zipzoomfly), and all are the G2 version. Trying to find out what the "01" and "C1" mean. Anything worth worrying about, or are they all basically the same? There are slight $$ differences from $3-$10.
  • SSDSA2MH080G2
  • SSDSA2MH080G201
  • SSDSA2MH080G2C1
Also, if anyone knows where these are in stock for a good price, please let me know. The cheapest I've found are ~$240.
J
jwwpua
In case anyone is interested, this is what I found:
Packaging Numbers (last two characters)
01- OEM without spacers (7mm)
C1- OEM with spacer (7mm + 2.5mm spacer)
R5- Retail Version with spacers and 3.5" adapter
Not sure what the spacer is for though. Necessary for mounting with a 3.5" adapter maybe?
Dermen
Florida
I was doing an Intel quiz about the X25 and the spacer has some function, I just don't remember what it is. It wasn't just to make it fit in the adapter though.
EDIT:
"a top-mounted plastic ring that gives the drive more rigidity as well as a bit more mechanical shock/vibe protection. Intel claims this affords the drive a 50% increases in operational shock resistance."
J
jwwpua
EDIT:
Ah thanks :)
