- Mar 29, 2002
I have recently heard that aside from stepping, all Athlon XP models (ie:1500-2000) are the same, the only thing different is the factory set multiplier setting, is this true? If it is wouldnt that mean you could buy an XP 1500+ and o/c it to the speed of a 2000+ without any significant heat gain or sability problems (provided that you unlocked the processor first and only used the multiplier to overclock with)?
Athlon XP 1700+, 256 MB CAS 2 RAM, Asus A7V266-E,
SB Audigy Platinum, PNY GeForce 3 Ti-500, Koolance PC2-601 water cooling
