I believe the EVGA precison Overclocking tool can regulate fan speeds based on temperature, but it's been a while since I used it...if nothing else you should be able to create a profile or hot key that triggers it to speed up during 3-D gaming only.
http://downloads.guru3d.com/Videocards----Overclocking-&-Tweaking_c13.html
Features:
Independent or Synchronous control for fan and clock settings in a multi-GPU system
Allows up to 10 profiles, and ability to assign hotkeys to these profiles to allow in-game
Ability to view temperatures in the system tray
Core/Shader Clock Link/Unlink capability
Fan Speed manual or auto adjustment
Real-Time on-screen display support for ingame temp, framerate, and clock monitoring
Logitech Keyboard LCD Display support
In-app temp/clockspeed monitoring of GPU's
Information button shows device, driver, memory size, BIOS Revision and SLI mode
Ability to choose different skins, and make your own!
Now you can save screenshots from your favorite games!
More info at EVGA
http://www.evga.com/precision/?utm_...=Feed:+EvgaForumRssFeed+(EVGA+Forum+RSS+Feed)
80c is about right for your card if you read most reviews...they can usually handle temps of 95-100c before major damage or slowing down (So they say!) but I prefer to keep my card temps at 70c or less for longer life. NVIDIA is a bit more concerned about it being noisy then if it runs a little on the hot side.
Just crank the fan speed up to 100% and you will see what I mean! (You will like the temps though..try around 75-80% for a bit better cooling as long as it isn't too loud for you)
