different sticks of ddr
elekt
los angeles, California
im kind of a newbie when it comes to ram, i already have 256 of ddr ram, and i am wondering if i need to match the ram, like brandwise for an upgrade? does differing speeds in different sticks of ram matter?
Top Hat Theater
Lost in Thought
I'd suggest getting an identical stick however it isn't necessary. I'd do it just to avoid any potential problems between brands (although I doubt there are any). Also, if you've got PC2100, don't buy another speed. Stick to whatever you've already got.
~THT
Anaxagoras1986
This is kinda revelant. What would happen if you had say...a 256 and a 512 of the same speed. Wuld it make a difference? I only ask this b/c I am pondering over getting a 512.
tragic_monkey
London, UK
running 512 and a 256 of the same speed may change the oc you get as differnet brand will give you different oc's and also you can get slightly worse performance when running two sticks, but currently you not overclocking so this wouldn't effect you. There is also a very small chance that you could get errors by running two diferent brand sticks but this is unlikly.
Anaxagoras1986
Ya but i was hearing that it was very demeaning to the performance. Not like just a little that I had heard of of having just 2 sticks.
SpyderMatrix
VA
could have two different speeds like pc2100 and pc2400 have problems in sandra soft when benching
