utabintarbo said:
As I recall, Volenti's block is epoxied to the chip (right?). I can't see a way to use an o-ring here - no way to clamp the block to the chip with sufficient force to seal. I suppose we could clamp to the socket or the mobo, but that almost guarantees a mess when removing the block for mods or whatever. Is there something I am missing here?
Bob
Yea my block is epoxied to the cpu package, I had no capability at the time to make a channel in the block for the o-ring.
I feel that, in it's current mounting setup, the block
should seal ok with an o-ring.
With the potential mess from removing the block (with an o-ring seal) in this block design I can give the intake hose a firm blow and force out the majority of the water inside the block (which doesn't hold a lot of water anyway)
In a normal vertical mount suitation you could position the exit hole at teh bottom of the block so you could get almost all the water out of the block before you take it off.
Albigger said:
That's great. i'll be watching the pump mod thread to see how it turns out.
what kind of head loss do you get due to your block? All this talk is making me want to go direct die even more now.....
Head loss is substancial, it reduces the no head flow of just a single pump to 1/7 , but that's the price you pay for more pressure...
800XL said:
A shim with threaded studs sticking out the top would be convenient way to attach the block. You epoxy the shim to the CPU permanently, and then design the block to use the studs for retention. That gives you a way to remove the block for modifications without having to take it apart installed on a board.
yes, I looked at that approach for a removable block, I can't see any reason why it wouldn't work well.
Tecumseh said:
This is why it is so important to get the jets right. Jet impingement
done right CAN beat copper...by a big amount. The key here is
"done right." The direct die WBs that have had poor performance
in the past almost certainly have been poor because of poor
jet design.
Anyone who wants to blow away conventional WBs with a
direct die design should focus efforts on optimizing the jet
design. This is the key.
exactly, my direct die block beats (temp wise) all my copper blocks bar one (which it matches) and gives a more stable (far more stable) overclock than that one. When I finish my 3 stage pump mod and (hopefully) gain signifigantly more pressure, we'll see if that can improve temps a bit more.
Liss said:
wut shows on the core????
and wouldn't the water pressure destroy the core over time?
I think he means he can see the stepping code stamped into the die.
oh sure, water is pretty erosive, especially under pressure, and will ,
in time, wear through the core, but I'll most likley be dead by the time that happens, so it's not something that concerns me
