T tandeme Registered Joined Apr 27, 2001 Apr 29, 2001 #1 would it be wise to use a 80 w pelt directly on the cpu without a cold plate? and what are some good ways to insulate pelts and water blocks
E eradda02 Member Joined Jan 8, 2001 Location Omaha, NE Apr 29, 2001 #2 you should defenently use a coldplate i think... my choice. and for insalation get some Neoprene Rubber you can find it at dangerden.com
F Fro Registered Joined Mar 14, 2001 Apr 29, 2001 #3 you want the coldplate. it dissipates the heat into a larger area for the pelt to pump away, using the entire surface area of the pelt to do so
B bdf24 Senior Member Joined Feb 15, 2001 Location Harford, WI. Apr 30, 2001 #4 eradda02 (Apr 29, 2001 06:53 p.m.): and for insalation get some Neoprene Rubber you can find it at dangerden.com Click to expand... You can also use the rubber on the bottom of all those cheap mouse pads. They only cost a few bucks! And its pretty much the same thing.
