disappointed with the first of my 1.6a's
saytan
2030mhz/127fsb is the max i've tried and stable, 1.625v
using abit BD7 and 512mb crucial DDR @ DDR200
lets hope the other one i have is better
funnyperson1
Senior Member
yep its too bad you ONLY got 400mhz out of your cpu...what a shame lol;) ...cheer up man...hopefully your next cpu will make the jap sites jealous like 3.0GHZ on air or some stuff like that....:beer:
S
saytan
its my cousins machine, im just setting it up
hes happy, he came from a p3 800EB, and hell the 1.6a's are meant to get better with a little time
thing is we ordered together from the same place so im paranoid my chip will be the same now :/
batboy
Senior Moment
Kansas, USA
Probably just needs more cooling and more voltage. Those Northwoods act like they hit a wall, then you pour a little more voltage to them and they start climbing again. Of course, you need better cooling before bumping the voltage. But, shhhhh! Don't tell your cuz that, so you'll have a faster machine... lol.
TC
Senior Seti Addict
Denver, CO
1.6 volts is not enough to bump that up to 2400. I'd try at least 1.7 before you give up.
Yodums
Senior Member
Ottawa, Canada
Better, cooling and voltage is what you need probably.
What you can also try is looping through the Prime95 torture test, seems like it'll help where you didn't get what you wanted out of the box.
Yodums
jdmcnudgent
tOLEDO, OHIO, the heart of it all!
you need more juice, do the v-pin mod. your ram is good, and you should be able to get a little higher with the mod. the bd7 is very limiting without the mod.
Hellraiser
vienna, austria, europe, earth
well
slap me if i am wrong. i got my 1.6a a few days ago und freashly installed win98se. really freash. no drivers. no nothing.
i have infinion 256 ddr pc2100 cl2 layer 8 RAM
and a epox 4sda
at default voltage i can boot at 2400mhz.
although i´m not sure if the cpu throttels down the mhz when having problems....
i will soon install prime95 and other progs to stress it out and see if it runs stable...
btw can anyone tell me where i can get the files to check stabiliy on my setup?
thx
S
saytan
im going to go with the beta bios over vid wrapping, since im clumsy
cboniks
Akron, Ohio
I have a 1.8a and I couldnt get it to run @133fsb on my gigabyte 8srx until i wrapped my vid pins. It wouldnt even post at 1.8v without the vid pin mod. the same thing happened with my bd7r.
As soon as I did the mod booted right up at 133 and my memory is @166. thats my experience with it.
S
saytan
this one posts and runs windows tasks just fine at 2133, games and high-stress apps are what make it fall over
immortalyinsane
sup
just built this rig(see below), seems to run fine. Be sure and up the ddr voltage, that helps. Runs fine at 2133 and it will boot at 150fsb but crashes in 3dmark at 2.4. overall it "can" be a good board but i am getting the booting issues most others are having. i am willing to bet your 1.6a could do much better than what you are getting, is it getting hot?
p4 [email protected] 1.5v
bd7-raid
2x256 crucial 2100 2.7v
asus 8200 gf3 250/530
2x ibm 307030
audio
cdrom... ect...
