Your socket temp was getting way up there on that last screenshot, my money is on the board.
Yeah... you mean the CPUTIN don't you? It stuck at 65°C after 15min while running prime bend. Do you know where exactly that sensor is located? I'm asking because i've seen discussions about the CPUTIN-value that always seem to be a lot higher than the CPU-"package"-temp just like in the screenshot.
So far i've rised the RAM voltage to 1.55V (in bios it was set to "auto" with a range from 1.25V to 1.9V)
I don't have a spare-computer to test all the parts seperately but i'll give it a try to remove the RAM-sets one after another.
It was using all 16 g of ram? Have you run a virus scan, maleware scan etc???I just experienced something. I started checkdisk for one of my hdds. While waiting i started playing pathofexile when i noticed that didn't run as fast as i experienced sooner. I barely played for 5min and the display-driver crashed. When i was able to close it i looked in the taskmanager and the mmc.exe was eating my whole RAM.
Might be a big clue to a RAM-failure, what do you think?
Meanwhile i closed mmc and everything works normal... (so the failure was not because of the voltage, but also it didn't solve it)
